It is currently Fri May 24, 2013 1:35 am
 Post subject: mx63 suspension
PostPosted: Mon Dec 19, 2011 11:09 am
Was lookin for options on my 84 cressida suspension.
i can find lots of options for a 83 and 73 and was wondering if anyone has tried that suspension on the 63. Ive heard of usin other suspension from other cars but none of them have been clear to me i always find fourms that contridict eachother so i was wondering if any one has a clear answer.
 Post subject: Re: mx63 suspension
PostPosted: Tue Dec 20, 2011 1:28 pm
www.serialnine.com
-Ryan-
1987 k5 rock crawler
PostPosted: Thu Dec 22, 2011 10:40 pm
yea they are one of the companys i already found but as u can see they only offer x83 or x73 chassie parts i have a x63 and i have no clue if suspension from a x7 is the same as an x6
PostPosted: Sat Dec 24, 2011 7:54 am
shoot them an email. they have built stuff for x32's even :wink:
-Ryan-
PostPosted: Sat Dec 31, 2011 12:01 am
This is a link to my thread> '84 MX63 7MGTE swap
PostPosted: Sat Dec 31, 2011 12:47 am
I love that car. <3
- 1984 Toyota Celica Supra 5M/5 Speed swapped <3
- 1986 Toyota Cressida 5M/Auto
- 1987 Toyota 4Runner SR5 Turbo <3
- 1985 Toyota Celica GTS Convertible
PostPosted: Mon Jan 02, 2012 12:46 pm
already emailed them they were no help at all they said we have the suspension for the 73 but we cant tell you it will fit on the 63 and its alot of money to spend on a guess
7mx63 wrote:
see!! what are u suiong for front and rear??
PostPosted: Mon Jan 02, 2012 1:53 pm
Just spend money. Nobody is going to tell you it works. If you really love the car, and you really want a part, you will make it fit. If you have a Cressida, and a especially an X6, you need to be willing to cut/weld/drill/modify existing parts to fit. If not, you will be on a depressing downward spiral until you sell the car for a Corolla.
Front are SerialNine adapters with S13/14 Stance GR+ Pro struts (10k) with S13 camber plates. The camber plate orientation on the S13 is the same as the X6, just drill out the holes in the body or file them until the plates fit. The tension rods I made myself from parts available through summitracing.com and Ace Hardware.
The rear trailing arms I modified to use a standard NASCAR size spring (500lb rate ~9k). I also used some old seatbelts to act as limiting straps which IS VERY F'ING IMPORTANT. Some people have used AE86 rear springs with adjustable seats, but I couldn't find them at the time I was doing my setup. Rear shocks are just the Tokico blues, I haven't had time yet to make my own adapters for QA1 double adjustable shocks.
The rear trailing arm bushings weren't available anywhere, so I measured them, contacted Energy suspension and spoke with an engineer, who verified they are the same as the Celica Supra, and if you check the catalog, the X6 should now have rear trailing arms bushings available (same part number)
I have mentioned this all before in other threads related to the X6. Search "MX63" and you'll find them.
PostPosted: Sat Jan 28, 2012 12:52 pm
thank you
yea im on cut springs i have already made myself some limiting straps from seatbelts and the bushings info will be helpful too thanks
